Th350 converter choice for turbo motor
Hi i am fairly inexperienced with automatics and i just recently swapped my t56 out of my 280 z back into my camaro and replaced it with a th350 and yank eliminator 4000 stall i got from a parts car. The car weighs roughly 2800 lbs, now if i am going up a very small hill and trying to maintain the speed limit the car sits in boost. Going down the track as soon as i leave the line the tach does not go below 5000, and i feel like im losing alot of power due to the converter slipping. It is simply to large of a stall. Im in the market for a new one. What would be a good converter for a car with this weight, currently 3.7 gears, twin turbo 355, 60/63 turbo's (almost no lag what so ever) roughly 400hp ish on 6 psi will run 18 psi with race gas should be around 600 ish. Let me know what has worked well for you guys on the street/ track. Here is a clip of an 11.7 @ 119 pass the other weekend with a best time so far of 11.5 at 118 http://youtu.be/RC4hozS2lE8
