Stall questions.
Old 06-03-2012, 11:45 AM
14k
14k's Avatar
Default Stall questions.
I'm looking at a local circle d stall
It's a 3200 with 3000 miles he says it's a trailblazer restall. I asked what that meant. He says it's a tc out of a i6 that they rebuild to stall higher?
It's from a truck 4l60 would this fit fine in my z28?
Old 06-07-2012, 09:23 PM
14k
14k's Avatar
Bump.
Old 06-12-2012, 08:31 PM
Cra-Z Larry's Avatar
That's a good question!! I don't have the answer, but is 3200 going to be enough?? Depending on mods you may want to go higher, possibly 3600. I have a 99Z A4 w/4500 vigilante converter. It's a cam-only car w/full bolt-ons, moser12 w/373s. Combination works well, car 60's in upper 1.5s w/275-50-15 MT drs. Hope this helps with your selection! Larry.
Old 06-12-2012, 09:13 PM
LS-ONE_DAY's Avatar
I would email or PM Chris directly about this. I'd say it probably would not work but Chris runs the business so he'll know lol
Old 06-13-2012, 06:36 AM
Circle-D's Avatar
That sounds like our 278mm HP series. Yes, it will fit a 4L60 in a f-body. But like mentioned above, depends on mods and intended usage if it will be enough stall.
Chris
