what year 4l60e?
This is not entirely true. Although for the most part it is the same trans, there are some small internal differences and in most cases the input shaft is different. 290mm vs 300mm. You will be better off building the trans you have. 1995 is an off year, first year of PWM, so it uses a different wiring harness and spacer plate than any of the other years.
