4l80 into older vehicle?
Well really depends. Its a pass drop axle. So you just need a NP241C drivers drop becare as the later ones are sometimes electric shift. Also it will have the correct VSS in the the transfer case. Physically it should fit they are not really that big
Then you need to give the PCM input to tell it that its in 4low or it will shift funny.
The 1990 is the XJ based one isn't it?
