Question for those running Hughes flexplate and TH400 converter
Just about to order parts and I want to confirm a couple of things.
I have a 2001 6.0l and I want to run my TH400 with a SBC 8 inch converter.
If I order the Hughes SFI flexplate (Hughes Performance HP4004X) can i run either the GM (12563532) or the Hughes (HP3795) spacer? And does this flexplate need any modification to the bolt holes as the factory GM on does?
Thanks in advance, I did search but it seems all the info is spread over dozens of posts and I couldn't find an answer to this particular question.
Cheers
Cheers
