Coded Po700,po716 2010 camaro
Old 07-08-2012, 01:07 AM
midnightz/28's Avatar
Default Coded Po700,po716 2010 camaro
Last night I took my car to the track and it did not go the way I expected it too. First off the trans temp was running higher than normal. It was about 195-200. Not too bad due to the hot Texas weather. We were in the staging lanes just idling. All of a sudden it felt like it was taken out of gear and put back in (you know that little nudge). Cel on but it seemed to be running fine. Made a pass and I can not tell you how it felt, sorry I wasn't driving. But I think it was doing okay the pass wasn't what the car should run but it made it down the track. So then I drove it and when I got up to make a pass. I noticed that it did not change gears intact it was stuck in I'm not sure what gear but it wasn't 1st. I believe that it was in 3rd but don't don't know for sure. I tried to manually change the gears. Nothing happened except the s for sport was flashing. Onstar gave me the codes that I'm asking about. Does anybody have any insight on this?
Quick Reply: Coded Po700,po716 2010 camaro
