TC not locking what do I check?
4l60e 2008 complete pull out from silverado installed in jeep wrangler, shifts fine but was asking around why sometimes it pukes oil out vent. I was told drive at highway speeds,tap brake rpm should drop around 200. Did test and no change in rpm, so what do I check? Is it not locking or is it locked all the time?
More info the ecu and harness was flashed a three wired, I built the relay to supply v when brake is not pressed and broken at brake applied, the harness guy labeled two light blue wires to tie to the relay,
Any ideas what to test?
Thanks
Lowelll
Thanks
Lowelll
