TH350 install help/info needed
I have a TH350 with the JW bell housing, TCI flexplate and spacer, a standard old style TCI convertor. When put it all together there is a gap in the spacer and convertor, doesn't sit flush against the crank.
top of photo is flex plate, bottom is convertor
Do I need a different spacer? Is it okay to have this gap of about an 1/8 from being seated all the way?
