Swapping my t56 for a auto
Got my new 4l65e back from getting all good stuff in it said to hold 700 hp and a 3500 converter . I'm taking my 6speed out sat to do the swap . Can I use a fly wheel of a 5.3 auto truck ?
Take you fly and the 5.3L and lay them flat side by side. See if there is any diff in the highth of the two. If there is this will cause a few diff problems and will be a no go. But if they are the same highth and if it bolts up, and all clears in the bell housing, and bolt holes for converter line up, and starter bolts on and all the teeth line up I dont see why not.
