Converter lock up switch...
Old 04-26-2004, 11:36 AM
1F8TL02WS6's Avatar
Default Converter lock up switch...
Who here is running one?
I have a fully built 4L60E with a vig 3800 stall and Im intrested in a converter lock up switch, anyone on here got one? or have a wiring diagram that I could use to know where to tap in at? thanks guys.
Old 04-26-2004, 11:22 PM
1F8TL02WS6's Avatar
ANY one?
Old 04-27-2004, 12:08 AM
mikemodano9c's Avatar
hard info to come by...i did a search once and didnt find a good diagram or instructions...
Old 04-27-2004, 06:47 AM
Kevin 276's Avatar
Mine is being installed on my th350 that I am having built. Go here:
http://www.rosslertrans.com/ Ask for Carl
Old 04-27-2004, 03:02 PM
DanZ28's Avatar
I'm running one on my 2000. I'll take a look at the wire when I get home and let you know which one it is on my car. It's actually an easy mod to do..
Dan
Old 05-12-2004, 09:12 AM
KatfishRacing's Avatar
you will need to look at a pin out diagram of your pcm and determine which pin controls the converter lock up. Splice a wire into the wire that leads from that pin and run it to a switch. From the switch the other wire goes to a ground. When you hit the switch it grounds the wire and locks the converter.
2002 Pinout Chart
On my car, a 1998 it was pin 32 on the blue harnes the TCC enable control pin, a tan and black wire. Not sure what that corresponds to in a 2002 though
