Stock Stall speed 4L80e ???
Old 06-01-2013, 09:26 PM
MillsMotorvation's Avatar
Default Stock Stall speed 4L80e ???
I searched a lot no good info, so maybe you guys can help! 1996 Chevy van 2500, 5.7 with 4L80e. Number I found on the convertor is K234 K1, also has the letter (A) stamped all the way around. Do anyone know what it may stall to?
Old 06-03-2013, 08:48 AM
Circle-D's Avatar
That should be the higher stall 310mm option, called a B-82. I would guess about a 2000-2500 flash.
Chris
Old 06-03-2013, 07:52 PM
LongIsland63SS409's Avatar
Intetesting post. I thought all stock converters were low stall.
Attached pic of a tag on my stock converter. 2008, 3500HD, 3.73 rear, 30 inch tall tire.
Does the 2424 represent the stall speed?
Thanks,
Mike
Old 06-03-2013, 07:58 PM
Chris
thanks Chris will be get u a call soon for 3600. This converter don't have cuts on input part just flat spots is that right?
Old 06-03-2013, 08:16 PM
Circle-D's Avatar
Sounds good, ready when you are.... And yes, the 4L80 has flats on the hub.
Chris
Old 06-04-2013, 05:20 PM
Link for 4L80E stock converter identification and stall speeds.
Expand the GM section and select 4L80E.
Mike
http://www.tcsproducts.com/media/1/Converter_Cat1_9.pdf
Old 06-09-2013, 03:37 PM
Mike
Thanks alot for the link, seems to have good info, but I cangt seem to find my info not sure how to use it!
Quick Reply: Stock Stall speed 4L80e ???
