Adding a 4l60e trans cooler and temp gauge?
Old 06-14-2013, 07:47 AM
94 z28 A4's Avatar
Default Adding a 4l60e trans cooler and temp gauge?
Who all is using a trans cooler and temperature gauge on the 4l60e? My trans is built so I'm wanting to install a cooler and also a temp gauge just so I can keep an eye on it. What brand gauge are y'all using and do y'all have it mounted on the pillar or where? Also if y'all have any suggestions on running the wires for the gauge let me know.
Old 06-14-2013, 09:26 AM
mjs1012's Avatar
Im running a big tube and fin cooler on the condenser that bypasses the stock cooler. My gauge is an aeroforce scan gauge mounted on the pillar that plugs right into the obd port and pulls trans temps from the sensor in the trans.
Quick Reply: Adding a 4l60e trans cooler and temp gauge?
