TBSS not shifting into 2nd at wot
Old 07-15-2013, 06:54 PM
JDMC5's Avatar
Default TBSS not shifting into 2nd at wot
06 TBSS. Has a built trans and a yank 3000. Shifts fine at part throttle but will not shift 1-2 at WOT. I set the rpm and mph ridiculously low but still no luck. The scanner shows the shift is commanding, its just not happening. I'm using hptuners.
Also, after a rewrite entire/ letting the vehicle cool down, it seems the first time we try for a 1-2 it will actually happen. But after that it's no luck.
EDIT:
The only thing I can think is that the TCM is bad or maybe wiring. That or the trans itself???
I tried a heavy throttle (maybe 50% throttle) 1st gear pull, ya know, to maybe give it a little extra time to figure itself out......lol, and still wouldn't shift.
has anybody ran into a similar issue?
File Type: hpl
Old 11-18-2013, 06:57 PM
JDMC5's Avatar
this is old but for search purposes it ended up being the trans.
Old 11-18-2013, 08:42 PM
Moderator
mrvedit's Avatar
Do you know what it was in the trans that was bad?
Also, when it didn't shift, did it seem to stay in 1st gear or did it seem to shift into neutral?
There are one or two other threads where the OP is reported no 1-2 shift and neither I nor anyone else has given them good suggestions yet.
Old 11-19-2013, 08:27 AM
JDMC5's Avatar
Felt like it wasn't shifting out of 1st, banging the rev limiter. Funny thing is it would shift fine every time until it got up to operating temp.
Quick Reply: TBSS not shifting into 2nd at wot
