1994 4l60e shift problems
Ok so after figuring out my engine chirp problem(which turned out to be a couple bad roller rockers).. Got the intake back fired it up and it ran good in the driveway. So as i go to shift into Forward gear. all of a sudden its slams into gear, as if the idle was at like 2000rpm then putting into Drive. Thats about how hard itwent into gear. Also when i left the driveway it wouldn't shift into the next gear till 3100rpm, so on and so forth for all the gears. Even tried manually shifting it and still the same thing. Now here some helpful hopefully stuff to add: The gear selecter starts out with 2 as the low gear and then shows 3 and then D. Also when in 3 or in D it wont kick down when punching it (WOT). Never touched the trans or anywhere near it when i replaced the roller rockers. Left the cables Pos. Neg. undone for the two days working on it, also the front end was 1 1/2 feet raised the whole time, not sure if this matters but might as well list it. Thats about it any input would be greatly appreciated thank you , Dave
