Does this sound like a broken flex plate?
Moderator
Valve train noises are at half the RPM of the engine (crankshaft). Flexplate noises are at engine RPM.
A agree with DietCoke that it sounds like valvetrain - you are reving to maybe 1500 rpm and the noise occurs about 12 time per second.
Flexplate noise would occur at 25 times per second at 1500 rpm.
I suspect you won't even hear it under the car.
Moderator
