steel molded pistons in a 4l60e fitment ?
Moderator
I assume by "sleeve: you are referring to the Sonnax reinforcement sleeve for the input drum. The stock steel molded forward and overrun pistons will not work with that. That is why the kit comes with a custom overrun piston and you have to use either a old stock aluminum piston or the crazy-expensive Sonnax billet piston.
Last edited by mrvedit; 11-28-2013 at 07:08 PM. Reason: Typo - meant "or", not "and"
I assume by "sleeve: you are referring to the Sonnax reinforcement sleeve for the input drum. The stock steel molded forward and overrun pistons will not work this that. That is why the kit comes with a custom overrun piston and you have to use either a old stock aluminum piston and the crazy-expensive Sonnax billet piston.
Moderator
I meant that you have to use either an old stock aluminum piston OR the expensive Sonnax billet piston. Not "and". Sorry for any confusion.
And Happy Thanksgiving!
Ted.
Ted.
