need to know what tranny cooler to use and trans mount HELP!
Old 05-10-2004, 08:56 PM
ta_silver_bullet's Avatar
Default need to know what tranny cooler to use and trans mount HELP!
i will be using a used midwest 3000stall 10.5" lock up converter used for 10,000 miles and 8 1/4 mile passes. i wante dto know what size trans cooler i would wnat to go with? and also what trans mount poly or stock rubber? thanks alot chris
Old 05-10-2004, 10:56 PM
Stone0fFire's Avatar
i use the B&M 24,000gvw supercooler
and the energy suspension polyurethane transmount.
the cooler has supported a midwest 3400/2.0, and a yank SS4000
i havent had trans problems yet,
and i drive the car as hard as i can every time i use it.
the es poly mount hasnt given yet,
and that is great considering i am using the TransGo shift kit
with the "three washer" setting
and type-f fluid.
i went through two stock-type rubber mounts real quick with this setup.
(first stock and second one stock-quality)
Old 05-12-2004, 09:33 PM
CamaroCain's Avatar
another good "insurance" i always recommend when doing a converter is a trans temp gauge. I have heard too many stories of people frying their trans.
Old 05-12-2004, 10:42 PM
heyitsTaJay's Avatar
i use a 19k cooler, and felt alot better when i got the trans temp guage. its good to know you have a cooler, but to see the cooler working is great!
Old 05-13-2004, 01:02 PM
Thanks alot giys yeah i was plannig on doing the trans temp gauge for suer any other gauge sugetstions? and i am going with the 19k thanks
Old 05-13-2004, 06:41 PM
why 19k over 24k?
