Need a New Forward Drum
This is out of my 76 K5 Blazer. I figured I would post here see if anyone knows.
I am in need of a forward drum. I would prefer an OEM replacement. Anyone know where to get one?
Moderator
Ebay seller powertrainpartsplus has them around $75. For a '76 you need a 298mm input shaft drum, NOT the new 300mm input shaft.
I see brand new 300mm ones for $120, but don't know the part number for your 298mm one. Even the dealer price is only $175.
I'm not sure if its an original trans.
I found 15S143798 on the edge of the bell housing.
From what I can find is 1 I think is Chevy. 5 would be 75. S no idea then the last numbers should be the the last 6 vins of the car it came from.
Apparently Monster Transmission sells just the forward drum for 53 bucks. Then I can just use my current input shaft.
Or TSR has a forward clutch plus input for 60 bucks.
Moderator
The fit of the input shaft into the drum is critical or you will have leaks which will quickly ruin the trans. As far as I know, GM only sells the drum with the input shaft as one part #. Make sure the PATC drum is not a Chinese knockoff.
