TH400 users, builders
I have had some bad luck here lately. A local guy built my tranny and he builds a lot of them for a lot of local racers. Car makes almost 900rwhp.
I have everything that I could get cryoed. Billet fwd clutch hub, 300mm shaft and cast clutch drum, red clutches. So I have burned up 3rd gear.
First question. My shifter is a B&M ratchet. When I go into reverse it's like I have a half click from park and then another full click to get reverse to engage. Could this cause my 3rd gear to burn up?
Is there anything else I need to modify to make 3rd gear last?
Adding an extra clutch and friction for 6-count clutch pack in the directs is always recommended. There's a good chance you'll need to do a minor amount of machining on the piston for a TH400 direct drum though, the snap ring groove is lower on the 400 drums than the 80Es.
