Removing clutch pedal question (t56 to th400)
Old 05-11-2014, 03:11 PM
nvmy2000ss's Avatar
Default Removing clutch pedal question (t56 to th400)
So I searched and nothing simple came up. Just wondering I've swapped from a t56 to a th400, to remove the clutch pedal do I need anything or is it something that I can just take off? From glancing it looks like it's attached with a through bolt to the brake pedal as well. Any help would be great.
Old 05-11-2014, 10:03 PM
pac1085's Avatar
i would remove the whole clutch/brake/gas pedal assembly and sell it (they go for $100-125 it seems)
and buy an auto gas/brake assembly for like 30 bucks used.
Old 05-14-2014, 11:14 AM
GTO_kid_2006's Avatar
I just left it in, its not hurting anything, and with the shifter still looks like a m6
Old 07-03-2014, 02:46 PM
ezstriper's Avatar
just did it..pop off both springs, remove switches, take off the 13mm nut on the pivot shaft, slid that out, remove clutch pedal put shaft back in just don't over tighten nut..
Quick Reply: Removing clutch pedal question (t56 to th400)
