Trans Brake issues
Old 07-02-2014, 08:40 PM
CarolinaTA's Avatar
Default Trans Brake issues
I have a rossler trans brake in my car, I had someone test the solenoid when he had my engine out and have been told and verified it is good..... Where do i go from here, he said it was probably something in the pan that was not connected.
Old 07-04-2014, 08:28 AM
Detroit Gearbox's Avatar
What model transmission?
Old 07-08-2014, 03:52 PM
Predator T/A's Avatar
if its a th400 you need to check the valve behind the solenoid make sure its not stuck also does the trans have 3rd gear and reverse?
Old 09-08-2014, 11:40 AM
CarolinaTA's Avatar
Sorry for the super late reply its a 4l80E, and yes all the gears work
Old 09-08-2014, 05:26 PM
Jake's Performance's Avatar
I would suggest you call rossler for support for his product. It could be a solenoid issue, valve issue, or installation issue.
Old 11-03-2014, 11:59 PM
CarolinaTA's Avatar
Well it worked when i bought it from the previous owner, over time it stopped working at some point.
Old 11-04-2014, 04:49 PM
NorthTexasConverter's Avatar
Rossler's brake is very sensitive to pressure changes. Have you hooked up a pressure gauge to test main line pressure?
Quick Reply: Trans Brake issues
