Please help! 80e swap have reverse and what seems to be 3rd only
Ive rechecked my repin of the harness and I have the brown wire in the s position and stuck the white wire in the u position. Talked to my tuner and he said he used a 04 2500 os so that should be good. Is there anything else it could be? Upon first start up i put it in drive and it jerked forward like it should then after idling awhile to top off the fluids it went into reduced power mode due to a map code and has tried takin off in 3rd gear ever since. Any help would be greatly appreciated cause I'm really ready to drive this thing bad!!
