What size Trans cooler?
senicalj4579 what is the make/model of your cooler?
you guys running these larger coolers in front of the radiator/condenser area, is there any overheating issues in stop and go traffic? anyone in the South have these? its in the mid 90's here lately so i want to be safe and not overheat the motor.
I never had issues with it flat against the condensor. Once I moved it away I started having high trans temps and had to add a fan. For the motor I've switched to the eBay aluminum radiator ($150) and it works awesome in everything but 90+ temps. I'm missing some of the shrouding that leads up to the condenser and I think that's contributing. Also, having the AC charged and working good helps. When the AC is on high it kicks out a ton of heat. Being able to drop one fan speed can really help motor temps when its 95 plus. You're needle won't show it but if you have a digital gauge you can watch what AC does to motor temp.
