Th400 lq4. Converter to flexplate gap.
Old Oct 20, 2014 | 04:04 PM
tim_bo16's Avatar
Default Th400 lq4. Converter to flexplate gap.
I've neglected to ask this earlier, but my converter to flexplate has a gap. I used the tci flexplate and the spacer. The converter is pretty snug to turn on the motor as it's tight at the spacer. Should I just shim it and go? The converter is fully seated in the trans. Th400 and '03 lq4.
Old Oct 20, 2014 | 07:09 PM
burbalanche's Avatar
How much room is actually between the spots where bolts go?
Old Oct 20, 2014 | 07:22 PM
tim_bo16's Avatar
3/8"-5/16".
Old Oct 20, 2014 | 09:00 PM
JapCrap's Avatar
I had the same problem with my 5.3 and th350. I used three washers of the same grade and drove it without any issues for a year or so. Just make sure you have a little clearance between the converter and pump.
Old Oct 20, 2014 | 10:32 PM
93camaro_zzz's Avatar
This is what you need to worry about right here. Maybe one of the transmission guru's can chime in on what the max spec could be, but 3/8" is usually what you shoot for. If you are +/- 1/16" of that, I would be fine with it.
Old Oct 21, 2014 | 08:59 AM
tim_bo16's Avatar
So the verdict is shim it?
Old Oct 21, 2014 | 09:26 AM
M.BOZZ's Avatar
I have the same set up, lq4 and a 400 with the TCI 399753 plate and tci converter but I think my converter come's out to far from the trans. Did you check to see if the spacer fit over the nose on the tc ? ( old pic, to far away )
Attached Thumbnails Th400 lq4. Converter to flexplate gap.-20140411_180409.jpg
Old Oct 21, 2014 | 10:45 AM
tim_bo16's Avatar
Yeah, I do remember sliding the spacer over the converter snout. It turned by hand, just a little snug from the paint build up, but it did go on. So yours fit flush?
Old Oct 21, 2014 | 10:51 AM
Circle-D's Avatar
My concern is you said it was tight to turn. Can you push the converter all the way to the flexplate and does it spin. The converter pilot might be a little long and you are binding in the crank, which is not good.
Chris
Old Oct 21, 2014 | 11:20 AM
M.BOZZ's Avatar
yes it sits flush, and turned easy
Old Oct 21, 2014 | 12:17 PM
tim_bo16's Avatar
Weird.
Chris
I can still turn it, it's just definetaly not as free turning as some others I've turned by hand. This is just my first lsx build. As far as moving it front or back towards the trans or towards the flexplate, no. I cannot move it. The converter is from freakshow.
Old Oct 21, 2014 | 12:21 PM
tim_bo16's Avatar
https://www.youtube.com/watch?v=Db2C...ature=youtu.be
Old Oct 21, 2014 | 02:57 PM
jrpimp00's Avatar
http://www.jakesperformance.com/Tran..._FAQ_Page.html
How do I know the converter is completely seated?
The old "3 clicks" method is not an accurate way to determine if the converter is correctly installed.
There MUST be clearance between the converter and flexplate when the trans is bolted to the engine.
In a perfect world this would be 1/8" or .125" everytime, and you just bolt it up and go.
In the real world, we have to check it and make adjustments as necessary.
On a typical GM engine, the flexplate mounting pads are 1" away from the bellhousing flange area of the block.
The converter pads when seated completely will be approximately 1 and 1/8th inch ( 1.125")recessed into the bellhousing.
Seat the converter, then measure the distance from the engine block bellhousing mating flange, to the mounting pad on the flexplate.
Then do the same from the transmission bellhousing mating face, to the converter mounting pads.
You should have the converter sitting deeper than the flexplate protrudes from the engine.
If so, you can now bolt the transmission to the engine.
With the trans bolted to the engine, you should be able to turn the converter freely.
Check the distance from the converter to the flexplate with the converter completely seated into the transmission.
You should have 1/8" to 3/16" clearance. (.125"-.187")
If it is more than 3/16", you should use flat ground washers to shim between the flexplate and converter.
Old Oct 21, 2014 | 03:15 PM
Circle-D's Avatar
Weird.
If you can not easily move the converter where it will sit flat against the flexplate you have a major problem. My guess is the pilot on the converter is a little to long and with the TCI extender it is bottoming out in the crank, which is very bad. Take it back out and measure how long the converter pilot is past the converter pad.
Chris
Old Oct 21, 2014 | 03:45 PM
mrvedit's Avatar
Moderator
When you have the right converter and it is fully seated, you can easily pull the converter out to touch the flexplate and then push it back in to make the gap.
jrpimp00 has all the right and critical measurements.
As Chris mentions, if you cannot easily push/pull the converter back and forth, you have a major problem that must be solved before you trying bolting it up.
Old Oct 21, 2014 | 04:13 PM
tim_bo16's Avatar
Did you guys see the video I posted? It shows how it turns. Man, I really don't wanna pull this thing. Lol. It was a pain in the ***.
Old Oct 21, 2014 | 04:36 PM
mrvedit's Avatar
Moderator
Yes, I watched the video.
If you cannot easily (e.g max 10 lb force) pull out the converter to touch the flexplate and "potentially" bolt up without any gap and without spacers, then something is WRONG.
The purpose for the spacers is so that the converter does not pull out so far that the pump is disengaged. Is is NOT to fill a gap you cannot close.
Old Oct 21, 2014 | 05:44 PM
M.BOZZ's Avatar
Did you get it ? if not, man I would just pull it back. If you think its a pain in the *** now, wait till it brakes and you still have to pull it out and then fix whats broke.$$$$
Old Oct 21, 2014 | 06:12 PM
Circle-D's Avatar
Sadly it needs to come out to check. But like these guys are saying, could get expensive if you don't check. And the problem you are having could possible cause a thrust failure in the engine.
Chris
Old Oct 21, 2014 | 07:10 PM
tim_bo16's Avatar
Man. Alright... Well, I will update when I pull it. Lol. Damn.
