4L60 makes noise.
4L60 makes noise.
My work truck is Suburban 1500 1999 year with 5.7 and 4L60. When I drive it with speed more 25 but less then 65, transmission makes load noise. Do somebody knows, what is can be wrong? Thank You and sorry for my English.
Moderator
The first step is to be sure the trans is making noise.
Often noise from that area is caused by a bad U-joint or noise that propagates from the rear end. A worn out trans mount is another common source of noise.
If that doesn't help you, tell us what the noise sounds like.
A metal-on-metal whining sound could be worn out bushing in the trans, but there are few reports of that on this forum. Usually it is bad trans mount or U-joint.
