4l80 turbo 400 dipstick.
Old 03-21-2015, 12:31 PM
geoguy1369's Avatar
Default 4l80 turbo 400 dipstick.
Hey guys I couldn't find anything on here about this. I have been told from a few guys in town here that the 4l80 uses the same after market dipstick as the turbo 400. Does anyone know if this is true? I know the 400 lokar fits the whole but are the level marks the same? Thanks for the help.
Old 03-21-2015, 12:39 PM
Bdiddy's Avatar
Just looking at some parts I have here I would say they are different. The length from the seal to the end of the tube and dipstick look different to me. You could probably call summit or jegs tech dept and get a better answer.
Old 03-21-2015, 12:44 PM
Jake's Performance's Avatar
Not the same. If you are using a Lokar dipstick, it's probably not accurate anyway.
Old 03-21-2015, 12:49 PM
geoguy1369's Avatar
So I'm guessing with the 400 stick when reads full will most likely be low on the 4l80 then
Old 03-21-2015, 12:51 PM
geoguy1369's Avatar
What dipstick do you recomend? I need a flexible tube
Old 03-21-2015, 12:54 PM
You will have to check the Lokar and make it read correctly. It should be done on any transmission install with any dipstick.
Old 03-21-2015, 01:06 PM
Bdiddy's Avatar
Jake what's the best way to verify this on a dipstick? Thanks
Quick Reply: 4l80 turbo 400 dipstick.
