4l60e neutral safety switch
Old 05-02-2015, 10:05 PM
Nastytruck's Avatar
Default 4l60e neutral safety switch
Hey guys,
I am doing a 5.3 vortec swap into an older ford truck. Think I got the wiring figured out EXCEPT how to make my reverse lights work. I've done a lot of searching but haven't seen a solid answer yet, just bits and pieces. I have the 1 plug neutral safety switch. Can someone please tell me step by step how to wiring in the reverse lights? Please help!
Old 05-03-2015, 10:37 AM
bbond105's Avatar
Is your neutral safety switch mounted on the side of the trans with the selector shaft going through it? If not what kind of shifter and switch are you using?
Old 05-03-2015, 06:43 PM
Nastytruck's Avatar
yes it is on the side of the trans. The trans is out of a 05 silverado
Old 05-04-2015, 02:01 PM
bbond105's Avatar
Here is a wiring diagram for a 98-02 F body. The wires maybe the same, as this is just a 6 wire switch. If there is a Lite green and a brown wire there is a good chance that these are the backup light wires. Hook one of these wires to a switched 12 volts and the other to the backup lights. It doesn’t matter which one goes where.
Quick Reply: 4l60e neutral safety switch
