LS1 to Powerglide clarification /Stall converter/flexplate
Hey guys, I am going all and and just throwing a powerglide in the turbo trans am. My car was a m6 and I already pulled it and sold the tranny. I am looking to install a powerglide I purchased. I have a few questions I need some clarification on
1: Is this the right flex plate and does it come with the hardware bolts to install? http://www.summitracing.com/parts/tci-399753
2: Will the flexplate above bolt to any powerglide torque converter?
3: Speed sensor? I have a ford 9" for the rear, and I do not want to run a speed sensor off the front wheels(if tire spins, it doesn't show tire speed) I want it to show transmission/tire speed. Ideas?
4: Stall converters?who has quality stalls( 3000-3800ish) at a good budget price? car is a gt45 turbo, water 50/50methanol injection 93 pump gas, ls1. with transbrake, 3.70 gears,
5: Also will the stall I WILL need the turbo shaft.\
6: Crossmember?
Thanks for any help or advice!
6: Crossmember?
As long as it's got a SBC/BBC pilot, sure. I would just verify bolt pattern spacing.
Clarify?
Midwest Chassis should be able to hook you up.
Flexplate is dependent on what converter bolt pattern you use. We have an option that uses a LS style billet front and will fit the OE 4L60 flexplate. Since you are coming from an M6 you will need a flexplate, the TCI you mention will work. But we also have options. Converter wise you will need the 30 spline turbine hub, which is 99% of the PG that we build. Be glad to help, you can give us a call or send us an Ask Chris form and we will get back with you.
Chris
Chris
6: Crossmember?
6: Crossmember?
