Steel braided lines...tranny cooler lines.....Easiest way...?
Old 06-30-2015, 10:47 AM
HISS's Avatar
Originally Posted by LS6427
Why....does the stuff get into your skin like little splinters...?
I'm gonna use steel braided hose.
No it's like small sharp pieces of wire that stab you. Easiest way I have found to cut it is a sharp pair of hand shears, like for cutting sheet metal. Some use a cut off wheel, or a chisel/blade setup, but the shears make a cleaner cut and don't distort the hose much. I've only see one stainless braided hose fail, it rubbed on some sharp sheet metal and had a small hole in it. The pushlock stuff is really easy to use, and I use it on vacuum/pcv setups. The thing I don't like about the rubber/nylon pushlock is it starts to deteriorate and crack over time.
Old 06-30-2015, 12:24 PM
transam69230's Avatar
I prefer the black braided hose ( not pushlock), easier to assemble, saves the fingers, and does the SAME damn thing as stainless.
Buy the right hose, it won't deteriorate and it will last. I have black braided nylon for every single fluid transfer system on my car.
Old 06-30-2015, 01:07 PM
86_irocz-28's Avatar
Originally Posted by Firebirdmuscle
I used this thread here when I did mine.
https://ls1tech.com/forums/automatic...e-install.html
^^^^+1 Did mine this way dont regret it at all I went with all russel fiitings/line as i got a discount also used a cut off wheel on a grinder to cut the line to length
Old 07-04-2015, 04:10 PM
Majestic9C1's Avatar
how much hose would be enough to get?? I have mine mounted dope style and I am still using the cooler in the radiator also...
I wanna say mine is a 70268 version
Old 07-04-2015, 11:38 PM
i bought 20ft was more than enough
Old 07-05-2015, 12:47 AM
-JP-'s Avatar
I used harbor freight large cable cutters for my -6 line and it is the cleanest cut I have ever had (when they get dull use the life time warranty for a new set), Then I used KOUL tools Hose and Fitting Kit to assemble them. So easy wish I would of found this set up years ago.
Quick Reply: Steel braided lines...tranny cooler lines.....Easiest way...?
