HINSON Motorsports GTO Transmission Mount Update
Old 06-29-2015, 01:22 PM
HINSON Motorsports's Avatar
Default HINSON Motorsports GTO Transmission Mount Update
As a lot of you know, we are in the final stages of our production run for the 04-06 GTO performance transmission mount (NOT AVAILABLE YET). The transmission mount has been developed to match our interlocking engine mounts that many of you already have. If you are interested in purchasing our engine mounts, they are available currently on our site. (http://www.hinsonsupercars.com/s-496...n.aspx#Chassis) Our new transmission mount will also have the interlocking stainless steel design that has been so successful in our engine mounts. The urethane blend is perfectly matched to our engine mounts to help keep your engine and transmission in place while you put the power down. I am starting a notification list of people that want to purchase as soon as the item is available. In order to get on this notification list, you will need to email me your contact information. The price for this item has not been set, but it will be known by the time this notification goes out.
*We do not need "test cars" for this item. It has been tested, so please do not bother me with emails like this.
To receive a notification email chris@hinsonmotorsports.com the following information:
  • Name
  • Phone #
  • M6 or A4
The final version of the mount will be black urethane. The blue was done for illustration purposes.
Installed.
It is an interlocking stainless steel design that matches our engine mounts. The triangle in the center was for mock up purposes. The top and bottom sections are floating in the urethane to help dampen vibrations.
Old 07-08-2015, 10:21 AM
Bump.
Old 07-17-2015, 02:59 PM
Hinson Motorsports performance transmission mounts for the GTO are now available. M6 mounts are in stock and we are taking Pre-orders on the A4 now.
Click Here to Order 6spd Mount (in Stock)
Click Here to Order Auto Mount (Available Aug 3)
Old 07-20-2015, 12:31 PM
Get on the pre-order list today.
Old 07-20-2015, 02:55 PM
elephantrider's Avatar
got mine in the mail on saturday ! will be installing this wknd
Old 07-20-2015, 03:25 PM
HURRY UP AND GET THAT MUG ON! Thanks for the business man. We know you will like the mount. It dramatically changes the driveline movement.
Quick Reply: HINSON Motorsports GTO Transmission Mount Update
