B&M pro stick shifter woes
Started adjusting the pro stick in my glide (4ft cable) 280Z with no luck yesterday. We spent hours messing with and could not seem to find the sweet spot. With the retaining hardware outside of the shifter housing there seems to be an excessive amount of back lash. The shifter mechanism is moving but not fully engaging or disengaging the shift points in both directions. In some settings we can get it to function in one directions but when shifting back up the slop comes back.
We noticed that when the cable was free from any bends the slop was basically gone. We spent amble time making sure there where no major kinks or bends and still have the same issue. I was under the assumption that if the cable was binding due to excessively sharp bends in the cable it would bind up and not create more slack like it is doing..
Further more there are plenty of other people running this same cable length/shifter/trans in a 280Z with no issues. What am I missing here? I know this isn't rocket science and it's driving me nuts.
Using a glide/all B&M brackets linkage cable etc. we tried the H per instructions and also used other with no luck.
