SFi Flexplate for 4L80E and long crank
I've read the sticky at the top of this section and I'm still none the wiser on what options I have to get my trans mounted up as it seems to be based on the short crank...
I've got an LQ9 with the long crank and a gen 1 style 4L80E transmission and converter with the big pattern (11.5"?)
So presumably I need a flat flex plate. But I can't find an SFI plate that will fit, surely someone has one that will fit?
http://www.jegs.com/i/JW-Performance...19-LS/10002/-1
JW makes one, technically not SFI approved but looks just like all of there other SFI plates. It is flat with 6 holes on the 11.5", fit the long crank no problem.
Chris
Chris
I took drastic measures today and turned my long truck crank into a short one... but left the center boss long so I can use a normal (old) 4L80 converter with a dished flex plate to save me having to then fit an extension.
As I've already got a dished SFI flex plate... now all I need is a converter for my 4L80, in the UK!
Yes, I turned 0.400" off. The holes were tapped full depth, so no problem there
I've got an SFI flexplate sorted as well.
I just need a converter now.... 3200rpm stall and good for 800hp
Sera
Sera
