Trans leak help!
Trans leak help!
My car sits quite a bit. Probably only been driven 5k miles in the last couple years.
So all the sudden my transmission starts leaking. I took it to a shop and he said everything looked good but he replaced bushings and gaskets. He also had my converter pressure tested and said he checked out fine.
He still thinks its the converter that is leaking. It is a Vigilante converter with probably less than 10k miles on it. Im sure it could be any number of things but is it possible for the converter to still leak if it pressure tested ok?
Any ideas? Thanks.
Any ideas? Thanks.
