Stage 2 transmission
I recently did a head n cam swap on my ls1TA and I tuned it and was fine I just bought a stage 2 4l60e from extreme racing transmission and installed it but for some reason after installing it i drove it and won't go into 4th gear and the speedometer starts going down but it's not loosing power can anyone please help????
Moderator
If the speedometer doesn't read correctly, the trans will not shift correctly.
There have been some posts about the VSS connector getting corroded or the wiring getting frayed. If those are OK, try replacing the VSS (Vehicle Speed Sensor).
I just bought the sensor and changed it I'm go a jump on the freeway and see if it lets me get into 4th gear
