Where to get stock trans lines?
Moderator
"Stock trans lines" means you plan to use the stock cooler which is just a simple tube within the stock radiator. Unless you are going to run a stock LS1 (350HP), a stock converter and drive easy, the stock cooler isn't enough. You should at least consider adding an aftermarket cooler and that means appropriate lines for it.
I do have a Performabuilt level 1 trans with a stock converter. I also obtained a flat cooler, about 12" square. Need to look at it a little closer to see what fittings I need to adapt.
LQ4/L92 head - ~400rwhp
Thanks for reminding me.
this thread has tons of good info...well worth upgrading the lines IMO
https://ls1tech.com/forums/automatic...oler-line.html
