Coolant in 4l60e
Coolant in 4l60e
Ive just discovered coolant in my 64 impalas 4l60e when i started the swap about 12 months ago I bought a new alloy radiator from summit with built in trans cooler from obviously its failed in some way the cars only been up and running for a few months.
My question is will what are the chances of get away with a flush and fluid change?
I waiting for summit to get back to me but don't hold out much hope for a positive reply.
Moderator
Sorry to hear of your problem.
This is one reason I caution people about using the stock trans cooler and suggest instead using only an aftermarket cooler (and bypassing the stock one). However my caution is partly because the stock radiators are now getting to be 15+ years old.
I have not heard of a new aftermarket radiator springing a leak like that. What brand is it?
I don't know if you have any legal recourse against the radiator manufacturer, or Summit if it was a "Summit" brand.
its this one https://www.summitracing.com/int/par...andz/overview/
Summit offered to replace or refund straight away but when i questioned the about the damage the trans will incur they responded
Response Via Email (Jesse) 08/18/2016 12:02 PM
Nic,
I apologize for the damages the radiator has caused, unfortunately we will only cover the price of the defective part that you purchased from us. We do not cover labor charges or extra materials/parts incurred in the process. I apologize for the inconvenience.
We appreciate your business.
Thank you,
Jesse
Summit Racing Equipment
i wonder how i legally stand?
Nic,
Thank you,
Jesse
Moderator
Wow, what a mess!
Its even an expensive $400 radiator from a well known brand. And a very specialized size.
As PerformaBuilt explained, the trans will need a complete disassembly and rebuild.
How many miles are on the trans since its last rebuild?
mrvedit by the time it got to the uk with shipping and duties it was more like $650 expensive for a strawberry milkshake maker! lol
The more worrying thing is the rebuild over here it could cost upto £2000 around $2600 as you can see from summits response they admit the radiator is at fault by the apology they've made for the damage the radiator has caused and not to offer any sort of compensation i think quite frankly stinks!
The trans was apparently rebuilt a couple of years ago,it was shifting fine and the fluid was clean when i put it in the wagon.
