Tru cool cooler
Tru cool cooler
http://www.transmissioncoolers.us/47391.html
I want to run this as a stand alone cooler and bypassing the radiator since 5.3 envoy and trailblazers have the problem where coolant may leak into the transmission. Also wanted to keep my transmission cool since temps reach 215. How can I do this without cutting my existing lines? I don't want to run braided hoses all the way to the transmission itself. My vehicle is an 06 envoy denali 2wd. I'm going to mount the cooler right behind the power steering cooler.
Moderator
Since the fluid in the cooling lines can reach 100 psi and 250F, I would strongly avoid any rubber lines or connections. I recall a thread where the OP used rubber lines which, when they sprung a leak, ruined the transmission.
