Trans fill tube install
Just got my FLT Lvl 4 trans bolted up and having a hell of a time getting the fill tube back in. Is there a trick to it?
Seems to be I just can't get the right angle.
Thanks for the replies.
Best way to do it is get it started into the grommet right before you slide the trans onto the guide dowels. If you've already bolted the trans up, use a wrench to push the tube up past the grommet.
