need some input on ratchet shifter option? 4l80e, hammer shifter works?
Old 10-20-2016, 02:26 AM
LS325ci's Avatar
Default need some input on ratchet shifter option? 4l80e, hammer shifter works?
I was looking at Hammer shifter, but summit say its not compatible with 4l80e?
jegs advertise it as one that works for 80e?
has anyone run the hammer shifter with 2000 model 4l80e?
I was thinking
B&M 75498
B&M 80885
are these two the only thing i need?
this is going to a chevy vega floor mount shifter.
the things I like about the hammer shifter
reverse lockout, backup light switch, neutral safety switch, lighted gear indicator.
Lighted gear indicator im thinking i maybe able to use for my custom boost by gear application as a trigger source.
and since this is a 100% street car, wiring a backup and neutral witch are great to have.
I t also appears to be compact/ shorter lever.
what do you guys recomend that has low design and has those features?
Quick Reply: need some input on ratchet shifter option? 4l80e, hammer shifter works?
