Read the sticky still confused on lq4
hey guys, picked up a 2000 lq4 with longer crank it will be going in my 2000 z28 with 4l60e, every thread or sticky I'm reading still has me confused on weather or not I can use this crank. Do I need a spacer? do I just change the flexplate out for the one that's on my ls1 block? Just want clarification thanks
The long crank will not easily work with the 4l60. No other flex plate will work with the long crank other than the factory flat 4l80 one. Kind of a bummer, but if you need a converter, you can get around it all with a custom built one.
-Brian
-Brian
Op you need a flat flexplate and a converter with the pilot milled down a little since the crank extends deeper into the transmission.
Here's a thread I made asking a similar question: https://ls1tech.com/forums/automatic...lq4-4l60e.html
my main issue is I want to reuse my stall converter it literally has less than 1000 miles on it before the motor went I can't justify right now spending the money for a custom converter I'd rather just swap cranks, I do appreciate the info
I would be having the machine shop balance and assemble everything for me
