Stall for 4l60
Stall for 4l60
I need a get a stall for a 4l60 going with a 5.3 need a 3400 but don't have the money for a circle d stall and don't want to switch cams. Which stall can I use that is cheaper than the rest and will last? Motor only has heads cam lifter and springs with the built 4l60
circle d , yank , fti are the ones with best results and good longevity.
If your budget isn't there you could always go with a trailblazer 6cyl convertor as a temporary solution until you can afford a decent quality stall , I don't know how well that or any cheap convertor will hold up to a cammed ls engine...
