*NEED HELP* flexplate to th400 needed vendors welcome..
Old 03-18-2017, 07:43 PM
FbodyFreak's Avatar
Default *NEED HELP* flexplate to th400 needed vendors welcome..
I am in the middle of a th400 swap and NEED FLEXPLATE advice.
The flexplate I originally got is an curved hughes sfi for a gen 3 block. I recently changed to a gen 4 block.
Will I need a new flexplate? Or just an adapter?
Recommendations?
Tranny is a rossler TH400 t2.5
Converter is a PTC 8inch specd for stock style flexplate.
Any info or suggestion helps.....
Old 03-19-2017, 11:54 AM
FbodyFreak's Avatar
Anyone???
Old 03-19-2017, 12:58 PM
Game ova's Avatar
If it looks like this, then run it. Just did a swap...even used PTC.
Old 03-19-2017, 09:59 PM
FbodyFreak's Avatar
Yeah the one I have looks exactly like that pretty much..... no spacer was needed?
Old 03-19-2017, 10:21 PM
Game ova's Avatar
Nope, Just put it on and run with it. Beware though, you will probably have to grind a couple of the flywheel to converter holes. May want to check while they are out of the car. PTC uses the large bolts.
Quick Reply: *NEED HELP* flexplate to th400 needed vendors welcome..
