TH350/400 with 6.0L adaptor and flexplate
Old 07-14-2004, 05:12 AM
GTS346's Avatar
Default TH350/400 with 6.0L adaptor and flexplate
Is anyone with TH350/400 running standard bolt up pattern, normal off shelf converter built for that trans with a 6.0L flexplate, longer bolts and adaptor behind LS1 engine?
In other words not having to buy a special built TH350 converter with LS1 bolt pattern.
Old 07-14-2004, 06:24 AM
Fast SS on TNT's Avatar
I had to use a TCI Flexplate to mate up to my converter. I'm pretty sure you will have to toss your stock flexplate. It's for the best anyway, as the TCI is SFI approved, and is pretty damn light.
Old 07-14-2004, 08:42 AM
stangeater01's Avatar
i have a tci on my 6.0 with a 400 i have a standard th400 converter and i had to elongate the holes on the flex plate for the converter to work. i am not sure if you will have to do so but i did.
Old 07-14-2004, 09:14 AM
12secSS's Avatar
My 1998 Ls1 stock flexplate will work on my 8" B&M Race converter. The stock flexplate will bolt up to an SBC patterned converter. It has two patterns on it from GM. All you need for the 350/400 swap is the 3 speed 4L80 electric speedo parts, I am using a TH400 ... no other parts are needed ... no adapter plate, no special converter ... well maybe just the cross member as well.
