RPMs drag slowly down after let off gas
Old 08-04-2004, 10:02 PM
GoldLS1's Avatar
Default RPMs drag slowly down after let off gas
when i drive highway speeds (60+) instead of the rpms goin to 1200-1400 when i let off the gas the rpms stay up at whatever the current rpm is and slowly drag down as if it has a jake brake (like the semi's)... ne ideas??? i have a built 4l60e and a TCI 3800 stall and LS1edit... both very very new... ANY help would be appreciated. Thanks in advance. ZAC
Old 08-04-2004, 10:51 PM
2xLS1's Avatar
Your converter is locked at those speeds. If you have edit, you can look at the table that shows what the speed has to drop to in both 3rd and OD for the converter to unlock.
Old 08-04-2004, 11:58 PM
Ed Blown Vert's Avatar
If you touch the brakes, it should unlock.
Old 08-05-2004, 06:47 AM
GoldLS1's Avatar
I know its locked... so its a tuning issue??
I know it SHOULD.... but i dont know where to start or do u have ne ideas??
Old 08-05-2004, 09:08 AM
Ragtop 99's Avatar
If you don't want the converter locked when you are coasting, raise your 0% TPS lock-up speed to 100 mph. Probably should raise the unlock as well at 0% TPS.
