Cheetah SCS shifter - Do I need the A4 or M6 console?
Swapping from 4L60e to Th400, can I keep my A4 center console or go with the M6 console? Also, does anyone know the part number of the shifter we need, they have so many?
It would depend if you are going with the reverse or "regular" shift. For the reverse you are correct on your #. Just modify the A4 one. If you changed to the M6, you'll still need to modify it.
I have the cheetah. You will love it. It takes all of 2 fingers to shift
If you are building a TH-400. I would strongly suggest: reverse, manual shifter; with a transbrake. You just can't beat the combination. Get the best. 34 element sprags are a must. Don't go cheap or you will regret it.
If you are looking for some one to build it.. try MadMan ->-> one of our sponsors. Great guy to work with.
Good Luck
David
Good Luck
David
