What parts do i need to make my A4 stronger?
I am going to rebuild my A$ this winter with a friend(GM certified tranny guy).
And i just need to know what parts to buy. It is still running fine now its not majorly broken or anything.
Is there anyone that i can buy a complete rebuild set from with all the upgraded parts?
Thanks
Josh
Thanks
Josh
Ive been looking into this also, this kit here covers the main weak points in the tranny link
You can subtract the converter which they have priced at $275. If you want to take it further there are hardened input shafts/drums and even a larger input drum on this site, the list goes on..
This package deal comes with: an Alto master rebuild kit with an 8 clutch Red Eagle Power Pack and full thickness Kolene steels for the 3-4 clutch, "The Beast" reaction shell, pump bushing, case bushing, extra wide sun gear bushing, pump seal retainer, filter, heavy duty / high performance converter - #2 or #2L on the converter list, thrust washer kit, high performance Superior 2nd gear billet servo (not a Corvette servo), high performance Superior overdrive billet servo, oversize pressure boost valve, 29 element Borg Warner forward input sprag, 13 vane pump kit, performance 1-2 accumulator spring, special intermediate servo release check valve, high output pump slide spring, Raybestos Pro Series black Kevlar 2-4 band and the freight is included anywhere in the 48 United States. All of this can be yours for $904.00. You can add or subtract from this package deal.
