replaced 2-3 solenoid but still having problems??????
ok so i dropped the tranny of my 02 ss and i replaced the 2-3 shift solenoid thinking that it might fix my problem of it not shifting from 2nd to 3rd....but it didnt......any suggestions? im pushin 455hp to the wheels, with a stock tranny though....im thinkin that could be my problem.....the car doesnt even try to shift into drive or overdrive, it just redlines....anyone have any suggestions?
anyone know of anywhere to go to get these that are recommended for 500hp+? and what else should i do so that my tranny doesnt go out...... or would i be able to put like a z06 tranny in it? does it bolt up since its all ls1 sh*t? im not very knowledgable with tranny's and stuff like that, please help.....
How hard was it to replace the solenoid and do you have to drop the pan and valve body?
I keep getting the 1-2 shift code and sometimes the tranny will not kick down from 55 mph.
not hard
it was pretty easy, i have access to a lift which made it a lot easier, but its like 12 or so bolts, just take them out (after the engine is cooled so you dont burn yourself) let the fluid drain, and then theres the solenoids, they just pull out after you take a retaining clip out....its pretty simple.... just make sure you replace the gasket when you drop the pan
