TH400 w/GV Overdrive
Old 02-27-2005, 08:56 AM
Mekkadon's Avatar
Default TH400 w/GV Overdrive
Which one of the sponsors on this site sells a TH400 with Gear Vendors overdrive for a 1998 LS1 Camaro?
Old 02-27-2005, 10:42 PM
James B.'s Avatar
They are separate. The easiest thing to do would be to buy a 2WD TH400 from the vendor of your choice and then buy the GV directly from Gear Vendors. Randy Palmer is still with Gear Vendors as far as I know, he's a great guy - loves to hear about his customers' projects.
One little bonus to think about - the GV has a VSS output you can feed your PCM with. No TH400 reluctor ring or VSS conversion to worry about.
Old 02-28-2005, 12:37 AM
Sandmann120's Avatar
James, I did not know that about the GV. Thanks for the input. Too bad they are so high priced.
Old 02-28-2005, 06:36 AM
Mekkadon's Avatar
Thank you so much for the information. My Pro Yank 4L60E is going ghost.
