Confused. High stall and stock camshaft....
Will this be worth it or, will I not get the full benifit of the high stall torque converter with a stock camshaft?
I'd like to keep the stock camshaft, but buy a high stall torque converter. Then I talk to car people that I know and they say a high stall torque converter with a stock camshaft will not be worth it, wondering you thought on this.
I had a lot of "car guys" tell me a 3500 stall was too much and wouldn't help my stock motor car (had an 99 A4); basically the oposite of what everyone here told me. I got the 3500 anyway and it was the best mod period. Drivability was good and my car droped .7 seconds in the 1/4.
So much for the "car guys".
Location: sojourning....looking for my city whose builder and maker is God.
With out a doubt! The best single mod for an A4 LS1 car is a high Stall tourque conveter. No other work is needed exceplt you might want some tuning on it.
Did any of you guys do any additional work to the trannys for the SSF3500 or the 3600?
i know this might be slightly off topic and im sorry but ive always wondered exactly what it was like to drive in everyday conditions and while racing with a high stall (i.e. 3400-3800), plain and simply ive just always wondered what they did while you are driving. thanks
sorry but do a GODDAM SEARCH!! this has been beaten to death, there is a thread probably a couple down from this one but...
3800 stall, stock cam. i had a BUNCH of ******** tell me that my car would be slower, it would NOT come out of the hole good , this and that with a high stall and a otherwise mostly stock motor. YEAH ******* right!. i dropped .6 and gained 2 mph! stall and traction (well- sort of for me= nitto's sometimes don't cut it).
like said before, you put a 3500 on a lt1, maybe too much i don't know. you put a 4200 on a ls1 with stock cam it'll LOVE it. it isn't like you rev the car higher with a higher stall so why would the stock cam make any difference? you make power to 5500-6k rpms right? though so...
Originally Posted by Red 01SS
I did add a trans cooler right away and later added a deep pan from TCI and a temp guage to watch it (it has been fine). The deep pan is not necessary but make sure that you throw a cooler on with a high stall converter.
When I install a higher stall TC and cooler, I want to monitor the trans temp.
Thanks
Originally Posted by 98A4LS1
Just curious, where did you install temp sensor at?
Thanks
Thanks
Thanks
Thanks
Originally Posted by Kenafin_02TA
We installed it in the line coming out of the tranny heading to the tranny cooler. Went to the autoparts store and fabbed up a t-fitting, installed the t-fitting in the line and the sensor in the t-fitting. (Saved about $40 over the same t-fitting that autometer sells.) You can also mount the sensor in the side of the tranny case. (Do a search on here...I found the information on here for mounting it that way if you don't want to do the t-fitting way) People also say you can drill a hole in the tranny pan and mount it in there..but that seems to be the least popular way.
Originally Posted by Lady Redhawk
Really, what would be the purpose of another sensor in the trany? If you don't have a scanner to read these through the pcm, can't you just splice into the one that is already there?
Originally Posted by rufretic
Its much easier to just plug in the sensor. There is a perfect bolt in the drivers side of the tranny. The sensor threads right in. It only leaks a few drips when you take out the bolt so you don't even have to drain the fluid. I can see my temps at all times and I barley have to take my eyes off the road.
