Any LS1 F-cars using a 4L60e Trailblazer converter?
Old 03-12-2005, 01:10 AM
Y2K2LS1's Avatar
Default Any LS1 F-cars using a 4L60e Trailblazer converter?
It should fit the fbody, the TB uses the 60e trans so why not. I read that the one to use is the one out of a inline 6 cyl TB. Supposed to stall 23-2500 or so. Can anyone verify this? Anyone using this?
Old 03-12-2005, 01:25 AM
transsam's Avatar
I assume it would work, but the work to get that low of a stall would be useless on an FBody.
Old 03-12-2005, 07:17 AM
K9 Pusher's Avatar
My wife drives a Isuzu Ascender, which is the Isuzu version of the trailblazer. I will say that for a 6 cyl SUV it definitely has some pull off the line. However, I'm sure like stated above, that the stall is still too low for a LS1 to see any real benefit from the swap.
Old 03-15-2005, 07:04 PM
JGA
JGA's Avatar
Default Stall OK
Hi
It depends on your car but, my z28 1998 A4 has a stall speed of about 1600 RPM I believe. Going with a 2300 stall is not ideal for 1/4 mile performance, but the extra RPM will still make a big difference on the street. It depends on how cheeply you can do it for. If you can find a used one at areasonable price and install it your self, I think it would be well worth the effort. I have been thinking about doing the same.
JA
Old 03-15-2005, 09:10 PM
CHRISPY's Avatar
It'll stall higher in the LS1 than the trailblazer. What is rated stall behind the trailblazer? (I own a 2002 envoy and the converter works very well)
Old 03-16-2005, 03:05 PM
SteveC's Avatar
Location: Poway, Ca. where GOD and the sun always shines
Originally Posted by JGA
Hi
JA
The stock converter in your vehicle is an 1800 stall 1.6 STR.
SteveC
Quick Reply: Any LS1 F-cars using a 4L60e Trailblazer converter?
